I am sure its been discussed but I can’t find it , has anyone tried cermark if so what settings did you use.
Do a search for “Cermark” and “settings” in the Beyond the Manual section of the forum. (All non-PG settings are listed there.)
I use it on aluminum at 600/Full. For best results, I spray two quick coats, letting each coat dry for 5 minutes. It’s important that you get even coverage. And, it needs to be sprayed in a well ventilated area.
I’ve started using alumamark materials now where I can, because it saves the hassle of using the cermark.
