These two images were prepared in Affinity Designer 1.6.0 for the mac
Affinity 4:
Affinity 3:
In the file …Affinity 4 the circle is drawn as a circle in GFUI. In the other it is drawn as a Square.
This seems like a bug somewhere .
<g transform="matrix(1.33333,0,0,1.33333,0,0)">
<clipPath id="_clip1">
<rect id="Background" x="0" y="0" width="1024" height="1024"/>
</clipPath>
<g clip-path="url(#_clip1)">
<g transform="matrix(0.75,-0,-0,0.75,0,0)">
<use xlink:href="#_Image2" x="0" y="0" width="1365.33px" height="1365.33px" transform="matrix(0.999512,0,0,0.999512,0,0)"/>
</g>
</g>
<g transform="matrix(1.08759,0,0,1.08759,131.02,-12.5121)">
<circle cx="350.102" cy="480.39" r="468.721" style="fill:none;"/>
</g>
</g>
I should probably have a word with affinity, too.
rotors
January 28, 2018, 9:50pm
The second one isn’t showing up for me.
Seeing first as a red outlined circle 6x6.
Second was an 8.5 inch white circle. Not seen until made the outline dark.
Oddness. I see two different size circles, you got a square.
Saw something about clipPath before, but would have to search for it.
Someone here will figure it out for you.
mpipes
January 28, 2018, 11:02pm
4
I opened the Affinity 3 file in Inkscape and while the circle is there, there is no stroke or fill assigned.
It would not even upload into the GFUI for me, this way.
I assigned a stroke to it, and it uploaded as a circle.
ah, the stroke. Thanks for spotting that.
I thought I followed exactly the same steps to create the square in each instance, but I guess I must have changed something in between that left a 0 width line in the “3” file.
The error was mine, it seems.
jaz
January 30, 2018, 6:05pm
6
Thanks for your help, @mpipes .
I’m going to close this thread - if you have any other questions, go ahead and post a new topic. Thanks for letting us know about this!
