I need to clean this image so I just have the image and wording as is for a project.
What do you mean âclean imageâ?
What design software are you using?
(Iâve moved this to an appropriate forum. âMade on a Glowforgeâ is for showing off your completed projects)
I donât need background just the image as is. Recieved image from a client. Trying to recreate in Inkscape and having trouble.
Lamar M. Ware
Find a matching font, lay out text on suitable paths, then trace the center graphic either by hand, or using the âtrace bitmapâ function. It might be easier if you adjust color settings beforehand, to make the trace more accurate.
Iâd agree youâll be better off recreating that, not trying to remove the image from the picture. Itâs going to look wrinkled if you take it off the photo.
(Thatâs a Freemason SymbolâŚyou can find it online.)
Thatâll make it even easier!
Probably right. Guess I will have to recreate it.
Lamar M. Ware
Thanks
Lamar M. Ware
Iâve beaten my head against the wall on this too,
so much so that itâs now a mantra,
âMight there be an easier way?â
Speaking as a Mason myselfâŚ
What you are looking for can be found by googling âMasonic Square & Compass Clip artâ
Here is a quick link: HERE. You might even find that exact image. As far as I know none of the Masonic symbols are under license (Kinda like Flags that way). Happy hunting.
Iâm pretty sure they predate copyright & trademark laws
