So I cleaned the interior of my glowforge today. It wasnt super dirty but I felt that it needed to be cleaned. I followed the instructions and VERY carefully removed the laser head. I used lens wipes on the lenses. I placed it back and made sure the ribbon had a good connection to the head.
Now, the glowforge loads a job and the head moves as though it is printing a job. However, no laser is shot from the head.
I then tried to make a cut just to test it. The head moved as fast as it does while cutting, but it basically just engraved a light line where the cut job should be. Also, it was a fat line, not skinny and fine the way a cut would be. This job was on basswood.
Any suggestions??? im really hoping there is an easy fix. I had some things in mind to make for the holiday season
I’m sorry that you ran into trouble after cleaning your unit. I’m glad to see you’ve already received some great advice from our other community members. Thanks folks!
It looks like your Glowforge is connected and you’ve been able to print since contacting us. That’s great! Could you please let me know if the advice you received solved the trouble you were having?
