I have been having issues with my air assist fan and cleaned it a few times but this time I removed the screws holding the fan to the chassis and find that I need to do a better job of the junk stuck there.
Same with the fan at the back of the machine - this needs unscrewing to clean properly.
How does this weekly maintenance affect the Warranty?
Weekly? I havenât cleaned my air assist in 17 months. Canât recall cleaning the exhaust fan yet either although I am probably not what you would call a heavy user either.
You might consider a better venting setup, with an external in-line duct/booster fan.
I ran an in-line fan pretty much since new (had machine since 2017), along with the built-in exhaust fan. I believe the additional airflow helped keep the interior clean, as I removed my carriage plate for the first time recently and the air assist fan looks almost new. Iâve only had to clean my optics a handful of times.
Youâre supposed to clean your machine regularly, so I canât imagine it would negatively impact the warranty as long as youâre following the basic guidelines for doing it. If youâre using corrosive materials to clean it, that may be another issue, but cleaning is good, especially if it needs to be cleaned!
There does seem to be a good number of complaints that begin with âI just cleaned my glowforge andâŚâ This leads me to believe there are some fragile connections in there that may be easily damaged if one gets over zealous with the cleaning routine.
Yes - but the cleaning instructions donât mention taking screws off - which to get to this dirt to clean properly it needs to be âtaken apartâ - I was looking for confirmation of where does it start affecting the warranty - where is the line
Aha. I guess thatâs a question for the legal team, but I will say: Generally speaking, GF seems to be quite good about stepping up to the plate on things like this. I donât know how they would know that youâve removed the screws to begin with, but I would be very surprised to see them quibble with you on warranty over what is basically routine/expected cleaning.
The warranty is here, and I canât say anything to change or interpret it.
Our cleaning instructions are available in the support site, too. We donât generally recommend the cleaning youâre showing, as itâs possible to damage your machine accidentally if you undertake this sort of cleaning. If there wasnât a problem caused, though, we normally wouldnât know about it and it wouldnât impact the performance of your Glowforge.
