I found a new way to clean glass and other hard surfaces and it works really well for the GF. I got a set of E-cloths from Amazon. They come as a set for about 15.00 and have a waffle weave and a smoother weave cloth in the set. You wet and wring out the waffle weave, wipe the surface clean, and while the surface is damp dry it off with the second cloth. This combination got stuff off that chemical based cleaners haven’t touched on my other glass and if you dry it with the second cloth there is no film or haze left. Makes my GF glass look new!
Sounds great, I’ll check it out!
I hate icky glass. I’ll try this.
Thanks for the tip! I will check it out on Amazon.
Great tip! Thanks
