Bit of a usability problem with the layer panel on the left.
When I have more than a couple layers, I may need to scroll the layer list away from home position.
When I do this, I frequently can’t access the layer menu - clicking (even using mouse and carefully not dragging) causes the layer list to scroll by one pixel and doesn’t open the menu.
This means I can’t access the menu at all for layers after about the 5th.
Expected: I should always be able to open the menu. Even if I have shaky hands.
This is in Safari Version 11.0.2 (13604.4.7.1.3) on a Retina MBP.
Workaround: Drag offending layers to the top position, scroll the layer list to home (first layer fully visible at top and can’t scroll up). Now the menu appears.
I think a lot of folks are finding that Chrome works better than Safari on a Mac. I know there were some serious issues with Safari and it might still be the case. I use Chrome in Yosemite and it works great.
We’ll keep working on this, but I’m glad you have a solution for now. If you run into anything else, please post a new topic or email us at support@glowforge.com.
