The gallery where I have had a lot of my work moved again (it is a pop up), so I spent some time building this display with integrated power supplies tucked behind (2 x 350 watts which is plenty).
Moat of these are recent with the 4 x 16 versions and the white faced ones being the newest. This is a cross section of almost all of my different style of clocks ( only last spring’s wall mounted vertical is missing) Also shown a few lamps and a wave.
The bug square one at the top required the pass through, all the rest can be done with sheets that fit inside the forge.
This video gives a closer look.
