Hello all,
I was using my pro with great success since installed (less than a week). I came in last night (Friday Jan 3) and it was stating it was offline. (GF was off and PC was sleeping Thurs night after use) When I power it on it lights up and the fan revs for a few seconds then lowers to idle. Nothing mechanical moves other than the fan. I’ve tried all the troubleshooting I can find in the forum including a factory reset. I have pulled the logs along with some network troubleshooting and have discovered the following,…its getting an IP address and I can ping it locally in my network so I know its connecting and can send/receive data ( I have confirmed this also with a local DNS server that is communicating with the GF).
Here is what I get from the logs after a factory reset (to clear them) and retrying the setup process…
2020-01-04_19:01:56.29993 udhcpc (v1.23.1) started
2020-01-04_19:01:56.34970 Sending discover…
2020-01-04_19:01:58.51522 Sending discover…
2020-01-04_19:01:58.59000 Sending select for 192.168.1.38…
2020-01-04_19:01:58.67013 Lease of 192.168.1.38 obtained, lease time 268435455
2020-01-04_19:01:58.71476 /etc/udhcpc.d/50default: Adding DNS 8.8.8.8
2020-01-04_19:01:58.71478 /etc/udhcpc.d/50default: Adding DNS 8.8.4.4
2020-01-04_19:01:59.23486 ERROR:root:401 Client Error: Unauthorized
2020-01-04_19:01:59.26484 ERROR:root:{‘ssid’: ‘MYWifi’, ‘bssid’: ‘ac:84:c6:c0:22:cb’, ‘wpa_state’: ‘COMPLETED’, ‘error’: ‘cloud_auth_rejected’, ‘mode’: ‘station’, ‘details’: “HTTPError(‘401 Client Error: Unauthorized’,)”, ‘pairwise_cipher’: ‘CCMP’, ‘group_cipher’: ‘CCMP’, ‘address’: ‘28:ec:9a:98:cd:08’, ‘in_recovery_mode’: False, ‘freq’: ‘2462’, ‘key_mgmt’: ‘WPA2-PSK’, ‘ip_address’: ‘192.168.1.38’, ‘id’: ‘0’, ‘serial’: ‘XXXXX’, ‘uuid’: ‘XXXXXX’} —>(removed)
2020-01-04_19:01:59.26883 192.168.192.10 - - [04/Jan/2020 19:01:59] “POST /setup/connect_and_check HTTP/1.1” 504 444
2020-01-04_19:01:59.34491 192.168.192.10 - - [04/Jan/2020 19:01:59] “POST /setup/connect HTTP/1.1” 410 0
2020-01-04_19:01:59.50620 192.168.192.10 - - [04/Jan/2020 19:01:59] “GET /logs/zip HTTP/1.1” 200 14658
After it connects (and the teal light goes out as expected), all the logs show that when the GF is trying to connect to google its unauthorized in some form or fashion
2020-01-04_06:35:29.58600 ERROR:root:401 Client Error: Unauthorized
or
2020-01-04_05:11:07.61335 ERROR:root:Failed to upload event (firmware_update:check:starting): 401 Client Error: Unauthorized
or
2020-01-04_21:31:18.35908 3690 INFO: net: requesting socket token
2020-01-04_21:31:18.77812 4112 ERROR: socket token request: http_code=401, result=22 (HTTP response code said error), details=“The requested URL returned error: 401 Unauthorized”
2020-01-04_21:31:18.79193 4116 WARNING: net: failed to receive token
2020-01-04_21:31:18.79198 4116 INFO: net: retry delay milliseconds: 2000 * 2.0 ^ 0 + 665 = 2665
I have emailed support but waiting on a response…Any ideas would be appreciated!!
I don’t think I or we can resolve this but maybe it will help someone else…
Thanks,
MjP
