When you use the compact filter and you switch the little button that says glow Forge air filter attached does the internal fan not run? I received my glow Forge today and I was very excited to set it up and I got the compact filter and I attached it but I neglected to click on the button in the settings so now both fans are running once I’m done running what I’m doing I’m wondering if it will reset it if the internal fan will not run with a compact filter attached and the correct button switched
Yes you have to click that button to make the internal fan not run. You don’t want them both running - it’s noisier and doesn’t help with keeping the air moving
Once you click it it will stay that way as the default, but if you ever remove your filter to vent outside (which you should if you can - SO much less expensive!) you’ll want to turn that back off
