Computer dies mid cut
My laptop is about the die and Im in the middle of cut. Will the machine stop? I have a desktop computer that is open to the same print hoping that the machine will continue.
Should finish just fine. The only time you need an internet connection (through your computer) is when your design is first uploaded into the GFUI. Once you’ve started your print, you don’t need it anymore.
You’re all good :slight_smile:
