Coolant tank
Just curious but can anyone tell me what this tank is and do I need to fill it? I assume it’s coolant of some sort but what and where do I get it?
:blush: Thanks
That is the coolant for the tube, it’s a sealed system and does not need to be changed or checked unless directed by GF in the process of following an error code ect…
I Have had mine run low enough to induce air bubbles in the tube. The coolant is a dilute solution of water and glycol (antifreeze).
Is your level low?
I haven’t had any problems and I can’t tell if it is low or not. I just was curious for any foreseeable problems. Thanks so much.
