We’ve been chugging along for a while now. I love the fact that the settings are saved with each design. One step better would be if you could select “copy settings” some way from one design to another. For instance, you’re working on similar projects, using the same material. Over the course of several cuts you need to use the same setting for cut/engrave/score. It would be awesome if another project already used the setting you were going to need to be able to select that project and say “copy.”
Just a though and a suggestion. Keep up the good work!
