Nothing big, but it came out well
That’s nice! (Not easy to cross the text like that!)
I’d love to see it made up. Do you have a photo?
Part of the cross is missing. The right arm is gone. Can you download it again if you have time. I love it. Thank you.
Looks great, Thanks for sharing!
Nicely done! There is a line under the text that should be made a score so it will not cut.
I added an outline cut to your design.
It’s not really missing, that’s just how discourse shows the file if it is too big to show all.
oh I told it to burn with a very light power so I could make sure it was placed correctly.
But how do you set it to be a score in the svg file?
thanks for the outline cut very nice
This is very well done, would make a perfect wedding gift to a couples
who are persons of faith.
Wow, I really like that. Thank you for sharing.
You did it right. Score is just less power than cut. I mentioned it because it would be easy to miss the line and have Glowfordge think it should be a cut line.
Nice job! What program did you use to do the text?
Where is the attachment for the file
The plain picture is the file. Right click -> save or click hold -> drag to desktop.
Hello, just saw your text. Right click the cross with missing arm and save it as svg file. Then open Inscape , when open just pull design into the box and click save… good to go
Wayne
love the design! someone else added an outline and i used their version to adjust the big LOVE so the large gap is gone.
i used your design with the outline and adjusted the big LOVE to get rid of the large gap
Very beautiful! Thank you for sharing.
