The problem with this is that if you ever change the number of slots, which @Jules was trying to do, you may not get the results you expect. If you increase the number of slots you want, or increase the number of pocket rowsāwhich will result in more slot groupsāthey will not be automatically cut, even though they will appear in the sketch.
[wrong!]The slots would not have to be selected with the method I suggested, therefor changing the number is immaterial.[/wrong]
Iām all for learning how to do these things more efficiently. This method is what I have been using over the last month or two as I have painfully learned how to anticipate the way that F360 will recalculate models when parameters are changed.
That would be excellent, Iād love to see some more alternatives. (I know itās probably like Illustrator and there are a dozen ways to approach itā¦Did you want to look at the original file too? I can PM it to you. )
@Hirudin, Iāll also send it to you to pick apart and improve on. The more minds on it the merrier.
Thanks, but thatās OK. The method jbpa outlined is probably the best method. Adding features to the timeline can be an advantage too.
Then maybe Iām not understanding what youāre saying. A screenshot would be helpful, if you can mock one up.
If I add the slots directly to the sketch created in Step 2, then when the number of slots change, they are not necessarily extruded correctly in Step 3. This is what @jules was trying to start with.
Ope, Iām sorry. Youāre right, it doesnāt work the way I thought. What I suggested was exactly what @Jules was doing already. (ā¦ I thinkā¦)
Well now Iām disappointed . Iām still hoping to find an easier, yet still reliable way to build these types of patterns. Letās hope @secret_sauce has some undisclosed tricks to share.
Actually, I now see what you did with it after reading through the explanation - you just created another sketch to distribute the decorative slots along the actual extruded face, instead of trying to extrude the body around them.
Roughly correct? I just hadnāt taken it far enough yet? (Hope I understand what you did there correctly.)
Correct. You could still do it with 1 sketch, but I like to split them up so that itās clear which is which, and it keeps more complicated sketches from getting completely out of hand.
Awesome-sauce! I actually understand!
Excuse me while I squeeeeeeee!
Is this the part where I pat myself on the back because I taught the infamous @jules something
Oh no, thatās entirely too easy to do!
By the way, I really recommend using the CAM workspace and functions for kerf adjustment, instead of building kerf parameters into your model. It makes calculations so much easier, and less error prone.
I didnāt build any KA into this file, and Iāve noticed that using the Save DXF function to adjust it on export does really bad things to the slot sizes when you have them sized to exact material thickness, so usually if I want to just adjust some finger tabs, Iāll only adjust those when I export one of the faces. (Leaving everything else alone.)
Seems to work a lot better.
I donāt use the Save DXF function. I use the AutoCAD DXF post processor in the CAM workspace. You can adjust for kerf on each individual piece of your model very easily; although not on individual slots or features of the model. I havenāt had any problems with slot sizes using this method. Of course, I also like it because itās very easy to export all of the faces of the model into a single DXF which can easily be imported into Illustrator.
Think in terms of your next tutorial, I havenāt even touched the CAM side yet and itās Greek.
Another area that Iāve learned through pain; although mostly with my CNC machines in that space.
There live dragons! Iāll do an entire design in F360 but hand off to something else for toolpathing. I mean I totaly respect those who can walk among the dragons and not get eaten but for me it is SO much easier to toolpath in Vcarve.
