Hi everyone! I’ve seen a few posts on how to engrave wood to create a depression to countersink magnets. Does anyone gave an idea of the settings to do this in acrylic? I want to create a memo board that I can stick on my washer/dryer for special care instructions.
Thanks!
You would use the normal acrylic engrave settings and make the number of passes necessary for the thickness of your particular magnet. Depending on the thickness of your acrylic, it may be easier to make holes for your magnets and use two layers of acrylic.
Thank you!!
As @dklgood suggested, I just cut holes and use some glue or two layers…depending on the use case.
