Foam cuts very well, and generally at a high speed/low power so I’ve never needed to put masking on it. The slower/hotter you go the more the foam will curl away from the cut - so a 2nd high speed cut is better than a slower single cut
If you’re doing something with a lot of intricate shapes close together you might need some, but that would definitely be an edge case!
