I tried printing some ornaments and cutting them out and it takes 7.5 hrs. I have done this in the past and it only took an hour at the most. What is going on?
Can you share a photo of your settings and the placement of your design on the interface?
I believe you could reduce time by taking the file into your graphics program and rasterizing it. That way, each ornament will not be treated as a separate entity. You may also want to consider lowering the lpi.
Try this for the engrave. Choose draft graphic and a LPI of 125.
You might be surprised the ornaments could end up looking fantastic. Experiment with one.
I use this setting when I engrave clear acrylic.
