Creating a "hollow" in 5mm acrylic
Hi,
How do I created hollowed out indentations in 5mm acrylic with hemicircle profile?
Lawrie
I think you would create the shape that you want (hemicircle) and then engrave until the shape has reached the desired depth.
Thank you…that was what I was planning to do but I have little experience in creating a drawing that will direct the laser into an ever deepening spiral downwards to create this ie what “fill” using Adobe Illustrator will do this?
Regards
Lawrie
Do you have a photo of an example of what you are trying to accomplish? There is no way to define the depth that you want the Glowforge to engrave, but any filled shape will be engraveable.
If I’m understanding you correctly you need to use the vary power engrave setting in the GFUI with an image like this - where white means ‘0 power engrave’ and black means ‘100% power engrave’.
If you do this in Illustrator you fill a circle with a radial gradient and then rasterize the circle before uploading to the GFUI.
Thank you.
I will try.
Regards
Lawrie
Here is a similar example.
And now I know about an eye surgery I had never heard of. Interesting how a machine like the Glowforge has expanded my field of interest and vision. How is your attempt to create a hollow related to the surgery - or is it unrelated?
If you need it to be anywhere near that smooth - after you engrave the above, hit the hollow with a blue flame lighter and it’ll smooth out quite a bit - not sure it’ll get that shiny, but definitely closer :slight_smile:
It is totally unrelated.
Lawrie
Thank you.
Lawrie
