I was going through my stash and found these old Chicago Transit Authority tokens. I wanted to make something unique (there’s a lot of cufflinks and earrings made from them) and came up with this. I’m not sure if I will sell them as pendants or keychains. Maybe both?
I’ve had my Glowforge plus for 2.5 weeks and I’m having so much fun with it! There aren’t enough hours in the day to create all the things I have swirling in my brain!
I used two pieces of 1/16 inch basswood so the back isn’t visible but I may make them one piece of 1/8 and encase the token in resin so that it can be seen from both sides.
Thanks. I was wondering if a nice tight fit and crazy glue in wood the same thickness would work. I have a few tokens kicking around I may try that with someday.
You could engrave replicas from acrylic, hit them with rub 'n buff while still in the sheet on the bed. That design lends itself perfectly to that process.
