I created a large Door Monogram using 3 Cuts and glued them together. Here’s what you’ll learn in this Glowfoirge video.
- Lauan plywood can vary in thickness, let your Glowforge do several or extra passes to make a full cut thru. Unofficial Settings - 135/Full 3 Passes for 3/16" Luan
- If you’re going to paint prime wood before cutting, the paint dripping off the surface can ruin a nice laser burnt edge.
- For Serif Typeface Outline the path to beef up sensitive parts that can break away.
Video Link - Glowforge Laser Wood Cut Door Monogram Great Lasercut Gift Idea
