The foam was cut on GF
Before cutting foam be overly cautious about ventilation. do not leave machine unattended
Nicely done. Is that a couple 1/2 inch layers stacked?
no it is one in layered. after much experimentation found one inch is about all glow forge wants to cut comfortably.
Nice!
You need to show a picture with the real handgun inside. Love your forum name!
thanks, didn’t want to offend with real gun
I am not offended by real guns, but I do appreciate your desire to not offend!
So, a thought hit me with this. Depending on how tight you want the tolerances to be, do you think you could have success if you had a customer/friend/etc take a picture of their items from a high angle, laid out on a piece of paper along with an object of known size like a qtr. Then you could angle adjust using the piece of paper and trace the items on the image. Giving you a perfect template for anything?
If so, this could be a cool way to make custom cases for people that are not close by.
Thoughts?
A two-dimensional is the best for getting proper tolerance. Your suggestion would work, I believe
