I have looked through the community section and googled everything I could think of without coming up with an answer.
I’m trying to cut rectangle pieces with words/pictures on them. I am able to score/engrave and cut each piece separately without problems. To save on materials, I would like to “marry” the rectangles together so that they are connected (i.e. right side of rectangle one with left side of rectangle two and both of them connected to the bottom of other rectangles). When I have them touching in inkscape, the laser makes a separate pass to fully cut each rectangle but I would like only a single pass on the areas that are touching. The problem is that it cuts into the previously cut rectangle and takes off additional cut (sometimes ruining the already cut piece by cutting into it) or burns the edge. How can I correct this?
Thanks!
