Hi, I want to cut out ornaments with stickers on them. I’ve tried capturing the shape with the camera but it’s not a clean line. Help please
Is the sticker already applied to the wood, or could you put it against an opposite colour paper to get a better line?
Once you scan it, there are tools in the GFUI that lets you edit the line too…
Or, if it’s just one shape, post a scan/overhead picture here and one of us can probably help ![]()
Thanks Deidre. I did the sticker design in Cricut so can’t export it. I did a screenshot and saved it as an SVG in Canva but it still ats a Bitmap doc in Glowforge
Do you have Premium? If yes there is both a Create Outline, and a Trace Image option.
Otherwise, if you can print it (or put your phone into the Glowforge bed) and use the default Trace Art option under Create A New Design.
