I’ve searched for this particle issue and can’t find anything. I am cutting out simple circles and squares from glowforge - not anything I designed or uploaded. It comes up with 2 lines and cuts out one square inside the the other square. I saw some answers to this issue but not for anyone using the glowforge designs inside of glowforge itself. How do I get rid of the line outside of glowforge’s designs so I can cut out a simple circle or square? I tried ungrouping but it won’t allow me to choose that. And deleting just deletes the entire circle? This isn’t an outline I’ve done. It imports this way. ?? Anyone who can help?
All I’m trying to do is cut out a square and circles on 1/8 Baltic. But my shapes have 2 lines instead of 1 line. My circle has one line but my squares have 2 lines?
I am using the glowforge and I searched for squares and these came up. I didn’t realize I had to use the “shapes” in GF? Ok that makes sense. I’ll try that. I hope it gives me the option to create oblong?
When you create a square, if you hold down the shift key, you can make it any height/width you want (rectangle). One additional idea on your double lined squares…you can use outline and it will put an outline around the outer shape then you could delete the double lined one…
