would anyone have the cut settings for Acriglas cell cast acrylic - I want to try this pretty Golden Blonde Pearlescent Acrylic Sheet. But they only come in 3/16
Thanks for any tips
Thanks for any tips
The easiest way is to make these the thicker it is the better as you can see what will happen with 1/8 material in a half-inch piece but not the other way around.
You could probably use the Thick Proofgrade Acrylic settings. If itβs burning too deeply, you can just speed it up a little.
Best Guess, take the 1/8 acrylic cut settings and divide by 1.5.
Make sure to take into account that the speed setting isnt linear, so consult the conversion spreadsheet to get a good speed number.
Thank you
