CutOptimizer — Automatic Inside to Outside Cut Ordering for Glowforge
See version 2 below for software.
Hi everyone,
If you’ve ever cut a design with nested shapes — like a circle inside a rectangle inside a larger outline — you’ve probably discovered the hard way that Glowforge doesn’t cut in the order your design file specifies. Instead, it groups everything by color and optimizes for speed, bouncing around the design however it sees fit. That’s usually fine, until the laser cuts an outer shape first, the material shifts, and all your inner cuts are now off.
The standard workaround is to manually assign slightly different colors to each shape in your design software so they show up as separate operations in the Glowforge sidebar. Then you drag them into the right order. It works, but it’s tedious — especially since you have to re-enter the same cut settings (speed, power, passes) for every single color group.
I built CutOptimizer to automate this.
What it does:
You give it your DXF or SVG file. It figures out which shapes are inside which, then outputs a new SVG where every nesting level gets its own slightly different color — close enough that they all look the same, but different enough that Glowforge treats them as separate operations in the right order:
  1. Open paths first (score lines, engraving paths — things that won’t cause material to shift)
  2. Innermost closed shapes next
  3. Outermost shapes last
You still have to apply the same cut settings to each color group in Glowforge, but at least the order is correct without any manual rearranging.
How to use it:
  1. Download the ZIP file, unzip it, and open it in your browser — no install, no account, nothing to set up
  2. Drop in your .dxf or .svg file
  3. Click Process
  4. Download the optimized SVG and upload to Glowforge
Everything runs locally in your browser. No data is uploaded anywhere.
Looking for feedback:
I’ve been testing primarily with SolidWorks DXF files. I’d love to hear how it handles files from other tools:
  • Illustrator, Inkscape, or other SVG sources — Does your file load correctly? Do the shapes look right? SVG parsing is the newest part and most likely to have issues with complex paths or grouped objects.
  • Cut order accuracy — After uploading the processed SVG to Glowforge, does the sidebar order actually go inside-out? A screenshot of what you see would be really helpful if something looks off.
  • Curve quality — If arcs or splines look chunky or distorted in the output compared to your original, I’d like to know.
If you run into problems, sharing the original file (or a simplified version that shows the issue) along with what you expected vs. what happened makes it much easier to track down.
The tool is free. Happy to keep improving it based on what people need.
Interesting solution. I’ve been using the Glowforge palette for so long that it no longer requires thought to get things to order exactly as I want them, but I can definitely see uses (complicated designs specifically) where making the computer do it after the fact would be easier.
yea, especially light weight materials like paper, etc. that can blow away when cut. Also if you don’t pay for the premium account, you can use it to convert DXF files to SVG files.
Matt
Okay, looking at the “nesting map,” everything looks great, but when I get it over to the GF, it is just two steps (outer and all the inner).
all the inners should be at the top of the cut list if they are all at the same level of nesting, they all appear together (as I would want). if you have ten circles inside a rectangle, you should see ten circles for the first cut, then the rectangle for the second. You don’t want to deal with each circle separately if there is no reason to. Does that make sense?
Yup, I just didn’t understand your design intent. In that case with my one test it works perfectly.
This is a great idea. Thanks for the share.
@matt22 Thanks for sharing CutOptimizer. Useful tools are always welcome.
Very nice of you to share this, thanks!
VERSION 2!
The last version did not handle units other than inches. This one handles them all properly.
Matt
CutOptimizer.zip (21.7 KB)
