I started a cut around 4:00pm today, using a design I’ve made before. The engraves and cuts all went well, but it skipped the last cut (even though it showed it in the animated preview)
I actually kicked off a second cut at around 5:10, turning off all the engraves and scores to try and fix the issue. It actually repeated the same behavior, cutting everything except for the last stroke and stopping early in the exact same place.
(This behavior also occurred this morning with a different design, stopping early before the last several cuts)
