So the current specifications on the website indicate 11.5" x 20" but 12 is mentioned in a number of posts that I’ve been reading through.
Which is it? Can it cut only to 11.5 but you can fit a 12" board in? I’ve been using 12x12" boards on the laser at the local maker space and would hate to have to trim a bit off every board to use.
Since the Basic and the Pro appear to have the same crumb tray / cutting bed design, designed to work with the Pro’s pass-through, you can place materials much larger than 12x20 – at work now, so can’t measure the distance from the inside of the front door to the back wall of the GF, but that’s the max physical size that would fit.
