I am needing to cut a 3/16" thick piece of delerin. Has anyone ever cut delerin? If so are do you happen to know of the cut setting to try? also any other preparations to consider?
Thanks,
Aaron
Thanks,
Aaron
I’m sorry I haven’t even used it yet haha still waiting for mine to come in
I’ve moved this thread to the Beyond the Manual section of the forum, as it’s the only place we’re allowed to talk about custom settings.
Just type ‘Delrin’ into the search bar and it will bring up multiple posts about it. Best of luck!
Ok, delerin is really melty so you will need to experiment and use several passes to get through. I’ve cut 1/4" with it and after decided to use a router bit against it next time.
I cut 1/4” at 115/full. It does create a bit of a chamfered edge due to the melting.
