When I cut circles, they are oval and do not connect. I have cleaned the track and belt and wheels on the carriage. All is smooth. Except the cuts.
You’ll want to check the belts and wheels again. Cracked/damaged/missing wheels or tensioner pulleys, improper belt tension, or a laser arm that’s out of square are the likely causes of that kind of distortion.
Thank you! As I thought after reading this, I need a new carriage belt. Too loose. I appreciate your help.
