Not sure what is causing my problem and hoping for some guidance. I have attached to file for you kind folks to look at.
For some reason, this shape is being cut multiple times by the GF software but I am unable to locate more than one path and the processing is set to one pass. I thought perhaps I stacked multiple copies but if I did, I can’t separate them so I can delete the duplicates. Any suggestions?
I’ve learned to love AI for creating my files but I have no idea what or why it does some things the way it does. I’m still learning and I haven’t cared to dig in that deep.
I have learned to check for this kind of surprise though, especially when I use the shape builder tool. It’s easy enough to miss if you get in a hurry and the GF will always remind you with extra crispy cuts as it does exactly what you told it to do.
I’ll give you weird but it did load and was parsed correctly by the app.
The object originally presents as a single path.
The Object → Expand command revealed a group containing a compound path.
When I released the compound path you I get the original separate paths.
The top path shown was just slightly smaller than the bottom path and had been subtracted to make the outline shown in the compound path.
I have no idea how the compound path became the single path from there.
If the position of the stroke is set to center that should avoid the double cutting - took me a while to figure that one out, and sometimes I forget to check that before I export it and tap that magic button!
Yeah, not ragging on AI by any means. Just appears the OP created a file with a stroke that translates into two paths. That’s not an AI or GF issue, that’s a user error.
I’m sorry you ran into trouble. It’s great to see that the advice which you received from other community members lead to a solution. Thanks folks!
If you run into trouble again, or have any questions, please post a new thread here on the forum or email us at support@glowforge.com and we’ll be happy to help.
