I have some sample books of wallpaper from 1937. I’m trying to determine whether these will be safe to cut on the Glowforge.
From my research, it seems these pre-date the use of vinyl in wallpaper, but some are glossy due to the application a variety of materials, including (possibly) linseed oil, other varnishes or (pyroxilin?) lacquer. Some with metallic sheen might have mica powders or thin applications of aluminum. And, of course, due to the age there may be formaldehyde or lead in the pigments.
I’m thinking this is likely not safe, but was curious if anyone had any knowledge, or knew of any tools or methods I could use to test these materials for safety?
Perhaps the matte papers (no metallic finish, no gloss) might be safe(r)?
Welcome to the forum @eva.pushkova . It is great that you are taking precautions before experimenting. You are probably right in assuming that due to the age of the catalogs, there is no PVC involved.
A simple test to make to find out if the sample contains chlorinated compound is mentioned in:
This test of course doesn´t rule out other dangerous compounds, but as @evansd2 mentioned above, I would be willing to try a small test sample.
When cutting any kind of paper/cardboard/fabric there is always a fire hazzard, so please have a squirt bottle with water at hand and be attentive to cancel your job at the first sign of a flare up.
Please do share your results with the rest of us, as this seems to be the first time someone has mentioned trying this.
