I posted this in the Made on forum, but I was going to post it here too once done. Then again, I figured I post what I have and let people make what they want of it.
I need bigger magnets for starters, but it can hold that model so 4 to 6 D&D figures should be able to be on there no problem as it is now.
Magnets are 1/8" x 1/16". I also plan on extending the supports under the platforms for more support if I keep the same size magnets.
After gluing the magnet in place, the stability is still not great. It can’t even hold a 1 lb weight. I might end up connecting the struts so they don’t push apart. I am still working with the same magnets since that is what I currently have. i am welcome to any suggestions to help make this better.
The front struts need to be longer on the top unless the top layer’s dimensions are redone.
I attached the struts on the bottom with some extra draft board and it can hold at least 2 pounds of weight. I added pennies to the bottom back of the top layer as a counter balance until the dimensions are fixed and I add magnets.
Thank you.
Design updated 6-17-2020
Added Ballista and Harpoon Gun and changed the struts to go under the play area for increased stability and weight the play area can hold.
