I’m working on prototyping put a new box with trays I am planning on selling. This is box A with configuration A, standard dice tray and mini holder.
Feedback is appreciated
I have a slightly different type of box setup for box number 2, considering using 1/4th Baltic birch for that one to see how that plays out in comparison to the 1/8th stuff used here.
I like it, I’ve never actually played so not sure what’s required as far as spaces. If I were to do anything, it might be to make the dividers moveable with a layer of slots on each end, and tabs on the divider piece (a quick example below of what I’d be talking about, and probably just the one divider in the big tray, but the smaller one could be doable). You could also mount a piece of acrylic, clear or white, to the underside of the lid as a dry erase board, just to add a little more functional value. Aesthetics-wise, I think it looks great!
How does it feel? Particularly when it’s loaded full, if it feels flimsy or like it might not hold together, then the 1/4" would probably be better, at least for the outer box part. But if it still feels sturdy and solid, then going thicker might just add weight and cost.
I’d suggest a way to keep it closed, a sub-lid for the dice section so that when someone stores it on its side the dice don’t rattle around - plus it would give a DM a flat writing surface behind the upright lid and I might also suggest a pressure clip on the underside of the lid so a DM could hang a piece of paper (with enemy stats, or lists of encounters, or whatever) - maybe even 2 of them.
It is against forum rules to ask for files. If someone wishes to share their design it might be in the free laser designs category or in this case, the designer may be selling the item in their online store, which is what he said he would be doing.
To be fair, this beta test was a mixed success. The hinges being so small were the failing point. The base of the box is great, I could have cut the tray smaller, I’ve just not gotten back around to working on the pattern since it’s so dang expensive to work with this wood these days.
At some point I made a note to try and convert the pattern over to 1/4th wood instead of 1/8th but leather is just so much more fun to play with these days
