Hi everyone!
So I received my basic on 9/28 and it has given me very little issues until 12/17 Thursday night. Today is 12/20 and it’s day 4 of my GF not working properly. Specifically, the entire laser tube and the laser head don’t move after the machine is turned on/whirs/thumps and the GFUI keep “centering”. It doesn’t finishing cycling through like it should.
The GFUI recognizes that the lid is open when it’s open and when it’s closed, it says it’s focusing (tube/head doesn’t move or make any sounds at all after it’s turned on) and then gets stuck on centering (no movement/sounds still). I’ve sent an email to support not too long ago and just waiting on a response.
Here are the things I’ve done:
Cleaned fans, belts are facing correct positions, lenses/camera are clean, GF logo is clean and visible, carriage plate is clean and moves smoothly. Wheels along both sides of the entire tube move smoothly when the machine is off and does not move when it’s turned on
Removed any/all things from crumb tray. Nothing is on the crumb tray.
Restarted/unplugged WiFi router (which sits less than 10ft away/across from my machine) as well as my GF machine multiple times with down/off times ranging from a few mins to overnight to allow enough time to for my wifi/GF to reset.
Tried connecting with hotspot multiple times (wifi was turned off for this).
Checked to make sure all lenses are not loose
Nothing is around my GF or blocking air intake from the bottom of the machine.
Tried the “move printer head to center of the bed so that the logo is under the camera, leave lid open, turn on GF, leave lid open for x-amount of minutes, close lid” trick hoping it’ll finish cycling through (this worked once when I had another stuck-on-centering moment a couple of months ago), but no luck this time.
Went through setup.Glowforge steps again and again trying to connect to main WiFi and also hotspot. Every time, my GF is able to successfully connect both our home wifi and the hotspot, so not sure if this still indicates a wifi connectivity issue…
Checked the 5 (3 black, 2 white) latches on the lid cables on the edges of the lid, unlatched them to gently wipe them and closed them back.
Cleared browser history, restarted laptop, tried connecting with my phone, tried different browsers (safari, chrome)
Kept the machine off Friday night, and also all day Saturday
This morning, Sunday 12/20, I just gave it a deep clean and went through all the above again…
Still not working…
After spending several hours reading up on on the GF website/community forums/GF facebook groups I’m apart of, I’ve tried almost every suggestion except for replacing the black lid cable… From what I can see, there is no visible damage to any part of the black ribbon, and I don’t want to replace it if it’s not likely the cause of why the printer head isn’t moving at all…
I’ve included photos that I’ve seen requested in some forum posts with similar issues…
Willing and open to trying any other tips/tricks or if any of you think there may be another issue I’m not catching?
