Can anyone tell me what the draft score default is ?
That would depend on the material. Just click the “>” to see the settings for what you have chosen.
Thank you. I was looking for a spread sheet to get an idea of a starting point on cutting some material. Is there a way to see what the settings are for glowforge products ? Maybe I could use that as a starting point.
Yes. Select a material, then click on the “>” to view the settings, as I said above.
Check out #6, you’re reinventing a lot of wheels
Your awesome! I took the spread sheet offered but I own a pro and not a lot to go off , plus it says Gillis different for pro. Vs plus/basic
Only above 100%, below it’s the same.
