Is there a way to delete projects in the design library. I have some that I don’t want in there anymore.
Yes, if you click on the little carat in the upper righthand corner of the thumbnail on the Dashboard, it will let you delete them. (Hover the cursor over the thumbnail to see it.)
Unless things have changed recently, it will not actually disappear unless you refresh the page. Also, it wasn’t possible to delete multiple projects at the same time… you can click the carat and choose delete but it’s wont (or didn’t used to last time I tried)
Correct. It gives you one chance to change your mind in case you hit the wrong button. Refreshing makes it final.
