Is it possible to cut Dibond with this thing?
“two 0.3 mm aluminium surface layers with a polyethylene core”
http://www.display.3acomposites.com/en/products/dibond/characteristics.html
No you can’t cut metal with a 45W laser.
Is that because it is reflective or just because it is metal?
If it’s because it’s reflective, then surely covering it with some sort of mask would solve that?
Because, being metal, it is highly conductive, so the heat is quickly carried away. Also metals have a high vaporisation temperature.
it should, however, be able to mark colored dibond.
Ah, fair enough.
