Here was my solution to direct vent my unit. It works flawlessly and I didn’t cover the window!
Looks good!
Is there something in the window frame such that you cut with the window open and it effectively acts like a blast gate when closed?
Nice solution!
My run is about that length. I found that an inline booster fan was really needed to eliminate all the odor.
that looks great. really nice solution to keep it from looking kludgey.
is there a screen in the window? is the screen in front of the vent hose opening? i only ask because i’ve seen screens clog up with residue when the fumes pass through. i had a dryer vent cover over my exhaust on the outside that came with a piece of screen in it. i didn’t take that screen out and it became clogged and backed up my exhaust a bit.
Basically I made a cabinet front with a solid bottom section to attach a vent. The following pictures will hopefully clarify.
There is a dryer vent mounted on the flat panel of the cabinet front. See the other picture I added.
I did similar, but now with a new machine, magnets shielded if used at all, and the Vivosun assist the levels of smoke moving by at any one time is much less so there is a lot less buildup than I remember as being commonplace. With just the Vivosun running most of the time it pulls along the exhaust fan keeping things cleaner and cooler still
