I finally got my glowforge to print (the carriage plate wasn’t hooked up properly. Printed out the gift of good measure but it’s almost like the printer had double vision and the circles arent quite circular. Any advice?
Post pictures - but likely in messing with the carriage plate you accidently over-loosened or over-tightened the belts.
Scroll to the bottom of this and see if your tension matches the gif - if it doesn’t, the instructions are the rest of that page:
Also double check that your belt is on with the teeth facing the correct direction as they go under the wheels, a number of folks have managed to put that on backwards or with the belt laying in the wrong place.
