Easy-Tack - do I need to wait?
From reading other posts, I found that some use Easy-Tack to hold down paper to a board so that the pieces don’t go flying all over the inside of the machine while cutting. I cut some draftboard about 1/2" all sides bigger than a piece of cardstock and sprayed it. Because it’s highly flammable, do I need to wait before using it, or can I cut right away? Because this will be my first time trying it, I just want to be safe. Thanks.
Let it dry completely. :slightly_smiling_face:
Definitely let it dry (it’ll still be tacky, but shouldn’t be off-gassing anymore)
I let it dry about an hour. Worked great. No more fly-away paper! I was making a bunch of jewelry tags. Yay! Thank you @Jules and @ekla!
