Edit in Group frustration
I am constantly going into edit in group mode when I simply want to move or rotate the group. I never use the edit in group feature and am wondering if there is a way to disable it so that it doesn’t interfere with the things I do want to do. Failing that, can you explain what I am doing that causes the edit in group to open when I simply want to move the group? I get the move symbol but then when I start to drag the edit in group opens and I am only moving bits of the design instead of the whole group.
I usually only auto-toggle it by double clicking the group. Unless there is a bug, I would say be careful not to double click. You can always select by dragging a box and then click and hold the left mouse button to move the object. Or use the arrow keys on you keyboard.
