Encountered a problem - Engraving
I am trying to engrave a cutting board for Mother’s Day.
After finally getting everything set up, I did a small test on the back of the board to confirm my settings I want to use.
Refresh bed, set focus, hit print. – Problem…
Print is cancelled and the message I receive is “filled shape is open. filled shapes must have closed paths. Edit your artwork to remove the fill or close the shape.”
This is a file I purchased and uploaded each component (svg) that I wanted on the board. I added the text.
I am not sure what is open and how to fix it.
Can anyone offer up an idea on what to look for or how to fix?
You can open the file in a program like Inkscape and rasterize.
I just had this issue with one of my own designs - and sadly the open shape was literally two nodes on top of each other, but they weren’t connected. I was able to fix it with selecting all the nodes and hitting the combine button once (twice and they all try to combine into one!)
The rastering that @dklgood mentioned is definitely easier, but you’ll want to double check that your settings still make you happy.
@dklgood @deirdrebeth
thank you. Unfornately, I am not familiar enough with either program to know what I’m doing.
I bought a session of classes for inkscape but I just could not figure out how to work it.
Which is why I generally purchase my svg files, versus designing. It is the biggest downfall for me because when something like this happens, I’m lost and clueless.
I will try to do some research and see how I may be able to fix this.
Thank you both.
As it’s a purchased design you shouldn’t post it here - but if you’d like you can send a direct message to me, and I can do a quick fix and then send it back.
You send a DM by clicking on the the profile icon, which will open a window that has a “Message” button.
In Inkscape, you just select your object (the whole thing), go to edit and make a bitmap copy. Then delete the vector image and you’re done…
Edit sent. I hope it’ll do what you need now :slight_smile:
Thank you all for your advice.
Thank you Deirdre for your help, it definitely made the difference.
I wanted to share the finished project.
