Oh, that’s gonna turn out neat! I’d try it but… yeah I’m not gonna try it.
And that’s why Ringling Brothers is out of business.
The PNG is here. It works great.
Here is a zip file, let me know if that works.
Mobile-GrayScale_Trees Flip.zip (1.8 MB)
Here is almost but not-at-all-quite your file as an auto-traced SVG, with slightly too thick black outline.
(what can I say, It’s friday)
Here’s the document info in the file:
Document Info - Fri Jul 28 19:52:23 2017
Document:
Color Mode: RGB color
Color Profile: none
Ruler Units: inches
Artboard Dimensions: 20 in x 12 in
Show Images in Outline Mode: OFF
Highlight Substituted Fonts: OFF
Highlight Substituted Glyphs: OFF
Preserve Text Editability
Simulate Colored Paper: OFF
Objects:
Paths: 1 (0 open, 1 closed, 4 points, length = 28.4194 in)
Compound Paths: NONE
Gradient Meshes: NONE
Symbol Instances: NONE
All Type Objects: NONE
Point Type Objects: NONE
Area Type Objects: NONE
Type on Path Objects: NONE
Clipping Masks: NONE
Opacity Masks: NONE
Transparent Groups: NONE
Transparent Objects: NONE
RGB Objects: 1
CMYK Objects: NONE
Grayscale Objects: NONE
Spot Color Objects: NONE
Pattern Objects: NONE
Gradient Objects: NONE
Brushed Objects: NONE
Styled Objects: NONE
Fonts: NONE
Linked Images: NONE
Embedded Images: 1
Non-Native Art Objects: NONE
Graphic Styles:
NONE
Brushes:
NONE
Spot Color Objects:
NONE
Pattern Objects:
NONE
Gradient Objects:
NONE
Fonts:
NONE
Linked Images:
NONE
Embedded Images:
Type: Transparent RGB
Bits per Pixel: 32
Channels: 4
Size: 71334K, 6809 by 2682 pixels
Dimensions: 490.248 by 193.104 points
Resolution: 1000 by 999.997 pixels per inch
Font Details:
NONE
Does it need to be a 1000 x 1000 ppi image?
Thank you so much for letting us know about this issue! We are investigating, and I appreciate the work you all are doing here together, too!
We’ve investigated, and it looks like there’s an issue in how we handle bitmaps that have been flipped. We’ll look into this more deeply so that we can make it better for everyone.
It looks like you’re in good shape for now. If you see this behavior again, go ahead and post a new topic.
