Anybody know settings for me to engrave on a butcher knives, metal
GF Staff and Support won’t help with settings for non-proofgrade materials so I’ll move this to a better place.
Also: the GF isn’t strong enough to engrave actual metal but if you use the search up too and look for moly lube or …mind fart…ah or Cermark, that’ll get you headed in the right direction.
The Problems and Support forum is for opening support cases. Support can’t help with non-Proofgrade materials, so I’ve moved this to an appropriate forum for you.
There are many existing discussions on marking metals (you can’t engrave directly, the machine does not have anywhere near enough power.) Use the Search option above, you’ll find literally dozens. In-general, you need a laser marking product like CerMark.
A Double Act!
Thanks it worked
