Engraving a cast paperweight
I have been a resin caster for about 15 years now. A friend wanted to know if I could cast and then engrave a paperweight. Does anyone have any experience with that? Looking for any and all input possible. This one hasn’t been polished yet. But it’s a start. 3x3x3 finished measurements.
The maximum height for anything engraved by the Glowforge is 2"
Even without the crumb tray?
Yes, even without the honeycomb tray. Also, what kind of resin did you hope to engrave.
  • Maximum material height: 2″ (50mm)
  • Maximum material height with tray: 0.5″ (13mm)
… unless you want to cut the bottom out of your machine, which has been done. I wouldn’t advise unless you are out of warranty and not worried about being denied future repairs.
Well. Thanks for that. No reason to research further.
Welll… that may or may not be true. You may well be able to make molds for your resin using the glowforge, all depends on your process.
I have already made some reinforcement boxes for my molds to keep them from warping. Nothing like making a custom fit lock and tab acrylic box in under 5 minutes.
And if you put additional cut/engraved layers on the inside surfaces of those acrylic molds, you could end up with really interesting shapes and surfaces.
Do you use a pressure pot? Would cut down on worries about bubbles in your castings when you have weird shapes like that.
Could also pour a single face, engrave that… then pour the rest to finish the block. Just a thought. That would also allow you to engrave the INSIDE of the cube, though I’m not sure how clear the engrave would come through that way… Worth some experimenting maybe? :slight_smile:
