I had much better luck with the Aldi brand because the rind is consistent and smooth, making the engraving process more consistent. Kroger brand was not coated consistently, and some areas were able to be engraved, and some were not. It may be trial and error if you do not have an Aldi near you.
Both cheese brands were 1 inch thick, so I removed the crumb tray and placed .4ā risers, and set the cheese on a .4ā cutting board. With the material being 1.8ā total (without the crumb trayā¦so -1.4ā) I set the material to custom .4ā height.
Inside the cardboard, the cheese is wrapped in paper and sealed with a sticker; that side is less smooth because of the folds, so flip it over and try the other side.
The settings I found best for the Aldi brand were:
It is more decorative, but if you decide to eat it you can cut off the engraved top and only eat the bottom half was covered with the wrapper. Definitely at your own risk and not FDA approved unless youāve only used your GF for food!
Isnāt the fan meant to suck out the debris, and not re-blow it all around?
Your caution is appreciated, many of the new and inexperienced users of this sophisticated equipment may not know that there are possible health hazards on eating anything that comes out of a laserā¦ or eating anything, for that matter Good of you to make a note about it, and as always, each user must decide their own comfort levels of caution.
(Iām also guilty of eating cookie dough before cooking! Probably more likely to get salmonella from spinach than eggs anymore anyway )
