You should move this to Beyond the Manual – otherwise the rules prohibit people suggesting settings for you to try.
Okay thanks
Looks real good.
Unfortunately, you’re going to have to do some experimenting (still) to determine what the proper settings are…the only poly I’ve cut has been some labels, and that is very easily burned.
Try either increasing the speed or reducing the power by half, run a test, if it’s not enough, reduce it again by half, then again. It usually only takes a few iterations to get to the best settings for any material.
