Hi! Does anyone have an idea of how I would go about engraving on this image. The problem is that I want to engrave on the white lines, not the black space but I believe my glowforge is reading the image where it is engraving on the black parts.
Inverting it will give you black around the original image and white for the lines, if that’s what you want.
You can also open this up in inkscape, select the shape and then set the fill to empty and the stroke to black. Set the stroke thickness and Bob’s your uncle.
Something like this:
Thank you! This was helpful!
